HELP
Need to find baler chain
Jason - Palmett
07-08-1999 20:53:25
I recently bought a Case Model 200 square baler. My friend operating the baler drug the pickup fingers on a hump in the ground and the drive chain broke. It looks like that large-linked chain used on planters and other implements. Can anybody tell me where to find this chain or a master link so I can repair it and finish baling? Thanks for any advice.
Tim(nj)
07-09-1999 12:22:03
 Re: HELP - Need to find baler chain in reply to Jason - Palmetto, GA, 07-08-1999 20:53:25
Roller or flat link? Any supply store or ag dealer can get it for you. Central Tractor has it, Shoup can has it. You can also try www.sloanex.com
paul
07-08-1999 21:00:49
Most any farm supply store around here carries doublelink chain, what number is it, 40, 50, ???
07-09-1999 19:01:00
 Re: Re: HELP - Need to find baler chain in reply to paul, 07-08-1999 21:00:49
It is a flat-link chain, but I am unfamiliar with the numbering of the types of chain. Can anyone tell me the measurements/ distinguishing characteristics of the different types? All I really need is a repair link - the chain is OK. Thanks for your help.
RickB.
07-10-1999 07:20:21
 Re: Re: Re: HELP - Need to find baler chain in reply to Jason - Palmetto, GA, 07-09-1999 19:01:00
When dealing with flat, detachable ink chain, every link can be detached from the next one (hence the name), there are no repair links. Most Ag equip. dealers will have some on hand. Take the chain with you to be sure of a size match, or carefully measure the width, pitch & link sidebar width.
paul
07-13-1999 21:04:25
 Re: Re: Re: Re: HELP - Need to find baler chain in reply to RickB., 07-10-1999 07:20:21
Most of the time a number is stamped on the link.
And yes there are repair links, altho you normally hammer the links apart from each other. But elevators often have a link with a pin to attach & detatch under tight conditions.
--->Paul
Tim(nj)
07-10-1999 21:00:57
A lot of detachable link chain has the size stamped in. Looked at my NI corn picker, and it has "55" stamped on every piece on one of the chains. Didn't look on any other equipment, but I'm sure I saw "62" stamped on my Zimmerman elevator chains sometime in the past.
