JD 480 Haybine
N Puller
10-29-2003 17:09:12
HI ALL.WHAT IS SO BAD ABOUT THE JD 480? NOT CRIMP GOOD,OR YOU HAVING TO WORK ON IT A LOT?I HAVE BEEN TOLD THAT SOME PARTS ARE DISCONTUED.PAID $200 FOR IT ALL IT NEEDS IS TIRES. HAVE NOT GOT TO MOW WITH IT.HOOKED IT TO THE PTO AND IT SOUNDS GOOD. KNIVES LOOK NEW. IT SET FOR TEN YEARS. WHAT DO YOU ALL THINK.
Bob Semrau
10-30-2003 09:06:44
 Re: JD 480 Haybine in reply to N Puller, 10-29-2003 17:09:12
I've hayed for 2 seasons now with a 480 that I bought for $150 and put another $300 into (including new tires) to fix it up, and it has done a good job for me. The one weak point I can think of is a coupler in the PTO shaft which will grind itself out if your rolls get stuck - this happened to me. I was able to find the upgrade part Deere came out with - which replaced this coupler with a sheer bolt assembly - from a junked out 480 at Stamm Equipment. Just go fairly slow and you'll be OK - it is still a big step up from a sickle bar mower. I pull it behind an Oliver 1600, but I am sure that my Ford Jubilee could run it if it had remote hydraulics.
Sid
10-29-2003 17:23:23
I have not had any experience with them but have bought some of that so called junk and get a lot of use out of some two hundred dollar equipment. HOpe it works well for you I think there is a good chance you will get your moneys worth.
