JD #5 mower
Alan Notestine
11-04-2003 14:03:06
I just purchased an old #5. It has a drawbar mount. I have a JD 420W that does not have a drawbar. Does anyone have any good ideas on how to rig an attachment?
Another question - I have a stand of alfalfa, timothy and orchard grass. Would it harm the growth potential to give it a cutting now or should I just leave it until SPring?
Dave H
11-05-2003 17:48:08
 Re: JD #5 mower in reply to Alan Notestine, 11-04-2003 14:03:06
First: Get you a manual. Go to ebay and find one that isn't going for an arm and leg. Type in "5 mower" and search.
Second: Block the mower, per the manual, behind your tractor.
Third: Fab yourself something that works. Hire a welder if need be. And, if you value your fingers watch how you raise the bar!
Delbert
11-05-2003 08:13:10
Alan if your 3 pt will go wide enough you can take the drawbar hitch off your mower and put bolts through where the hitch was and bolt to tug arms will work fine. I have done this on A NO.5 that i had.
Bob G
11-05-2003 06:28:48
I would make a hitch to fit the lower links on the 3 point. I have seen a couple made this way and they would very well and are easy to hook up.
Bob
Farmered
11-05-2003 05:06:59
Do not cut alfalfa within about two weeks of when you expect a killing frost. After the frost you can cut it any time. Years ago I was cutting a load of greenchop to feed the herd everyday with a flail chopper. Next spring I could tell exactly where I was when the frost came. No alfalfa up to the point where it frosted. Good luck. Ed
RJ-Az
11-04-2003 18:48:36
Hay Allen check out the site Retiredtractors.com
They have complete mounting instructions and tip for the NO> 5 mower. Scroll down thru all the stuff and youwill find it.
