3-pt. or trailer type sickle mowers
Jason
07-14-1999 07:14:42
Those of you with experience with these mowers, can you tell me what type is better- a trailer or a 3-pt? I've heard pitman, trailer type, can be a pain at times. I've also heard they're disadvantages to a 3-pt. I have a late styled JD "A", should I go with one like a #5 or buy a 3-pt coversion kit and get a 3-pt sickle? Which is better in the long one?
B.C.
07-15-1999 07:08:28
 Re: 3-pt. or trailer type sickle mowers in reply to Jason, 07-14-1999 07:14:42
I grew up using trailer mowers behind a 9N and currently use a 3pt Deere 9W behind our MH50. I had some experience with a belly mount on a Allis B.
The 3 point version is the best compromise between being easy to attach and doing a decent job. Back a trailer up for any distance, or dodge obstacles and you'll see what I mean.
If somebody ever came up with a belly mount that was quick and easy to mount and dismount, the world would use nothing else.
S.P.F
07-18-1999 05:40:57
 Re: Re: 3-pt. or trailer type sickle mowers in reply to B.C., 07-15-1999 07:08:28
IH had a belly mount mower (sickle) these had a special option you could run the sickle down,strait up or any position in between.
Using the tractors hyd. tolift the bar.
My neibor has one. It mounts on his 560
B.C.
07-19-1999 06:07:17
 Re: Re: Re: 3-pt. or trailer type sickle mowers in reply to S.P.F, 07-18-1999 05:40:57
Yeah, the belly mount on the Allis B my granddad had was like that. There was a pendulating link at the end of the pitman rod, and you could keep the sickle going at any position. One of the neighbors found a similar deal for the 9N they had.
But they all had the same problem in that it wasn't a trivial thing to mount and dismount the darn mower on the tractor. The Ford deal was set up so you could leave most of the brackets on, if I remember right, and take the bar off. But it still took time, and there was still stuff left in the way. With the Allis, which was a crank start tractor, you needed to set aside half a day to get the mower on or off.
Once they were on, you couldn't beat them for visibility, square corner maneuverability and all the rest. Both were hydraulically controlled and they both really worked nice.
Tom S.
07-15-1999 06:12:02
Don't know where you are from, but I saw an ad form a company in Tenn. that manufactures a 3 wheeled attachment with 3pt arms and PTO extension to mount a late model disc mower behind a antique without 3pt. It converts a disc mower to be towed. E-mail if you want further details. The ad was in Fast- Line. Tom
Theman
07-14-1999 10:19:04
I cut 4 acres of coastal bermudagrass with a JD Model 37 (trailer type w/pitman). It has the 7' bar. I have the trailer type mower because it can be handled by a smaller tractor. This is a true advantage. I use a 23 hp Ford 1710 and it isn't heavy enough to handle first cutting (weedy) grass with a 3-pt. Your A wouldn't have this problem.
A disadvantage of the pull-behind mower is the amound of turning it takes to make a corner. If your A is hard to steer (and most are) you're going to get a workout. Consider any obstacles in your field also. I'm a little persnickety about "rooster tails" left after a bad cutting job so I probably steer more than is necessary.
So...if you plan to do large acreage or custom work, get the 3-pt. balanced-head sickle. That's what the pros use. If you're just playing around (like I am), get any mower you want. Picture the machine you want to see behind that A and go for it!
Stan Theman
