Planter marker arm operation question?
52BMAN
11-13-2003 17:52:16
I am restoring a JD 246-247 3 pt. corn planter. I have an owners manual, but all it says is the markers will raise when the planter is raised. What mechanism is used to raise them. There is a chain and a lever to trip the markers. There is no chains or ropes from the markers to the hitch or tractor. Are there some pieces missing? Please help. Thanks!!
Leroy
11-14-2003 06:16:26
 Re: Planter marker arm operation question? in reply to 52BMAN, 11-13-2003 17:52:16
There is a flex in the planter that when you lift it will do the lifting of the markers, will lift both at same time and you can drop either one or both at the same time, late 60's when I last used one, I do have a book someplace that if you need more help I may be able to find it and direct you to information in yours
52BMAN
11-14-2003 13:42:57
 Re: Re: Planter marker arm operation question? in reply to Leroy, 11-14-2003 06:16:26
Leroy, Thanks very much for your help. It's nice to talk to someone who actually used one of these planters. Mark
