Plow tire
Aaron
11-18-2003 15:12:10
I'm looking for a tire for a JD trip plow. The blown tire is a 5.50-16, but I will take a 6.00-16. The tire I have has lug-type treads to grab when you trip the plow, and I would like something similar, at least something that would grip. Any help would be appreciated, thanks.
RayP(MI)
11-19-2003 16:54:13
 Re: Plow tire in reply to Aaron, 11-18-2003 15:12:10
If all else fails, get a coarse tread truck tire, mud and snow tread will work (most of the time!) I've seen plows with tire chains on the trip wheel too!
Jim was in UK
11-19-2003 10:57:24
Have you tried your nearest TSC or Gebo's? They usually stock tires and will most likely have one to fit your plow. Another place to look at would be the CO OP or Farm Bureau Store.
Jim
rustyfarmall
11-19-2003 04:41:13
Don't know where you are located, but here are a couple of choices. Both of these have websites. M.E.Miller tire in Ohio, or Nebraska tire in Lincoln, Ne.
Wayne in Pa
11-18-2003 17:22:22
Try Gempler's, 1-800-382-8473 or gemplers.com. They have a 6.00x16 6 ply with traction tred item no. 3306. Hope this helps.
Wayne
