Home made hay wagon
Marty
07-30-1999 08:52:58
Does anyone out here in cycberfarm know how to make a hay wagon from car axles?Like how to make the steering axle?I have car axles but need direction.
Aaron
07-31-1999 19:29:26
 Re: home made hay wagon in reply to Marty, 07-30-1999 08:52:58
Have you thought about using a junked ford truck? Weld the twin I Beam axle together and attach the tougue to the axle. Weld the truck frame to the axles and remove the springs. This should give you a wagon that will tow good at road speeds.
paul
07-30-1999 12:40:01
Do you have 2 front steering axles from an older car that was rear-wheal drive? Weld up one set solid so the tie rods are straight & solid. Look at any other wagon & weld up the tie rods onto a piviot so it looks like a factory front. Make sure you leave some thread adjustment in there some where to adjust toe it, etc.
--->Paul
