Pulling a ground drivin speader with a truck
A drivin man
01-15-2004 22:35:52
Has anyone here ever used their truck to pull their ground driven speader? If so let me know how it worked for you. Any information that those with this experance could give me would be most welcome. Thanks ahead of time.
JC
01-16-2004 23:01:15
 Re: Pulling a ground drivin speader with a truck in reply to A drivin man, 01-15-2004 22:35:52
I pulled an old John Deere spreader with my Studebaker 3/4 ton 2 wheel drive. Used it quite a bit. Worked great for me.
Been there, done that
01-16-2004 12:12:19
Ditto on the slow speed- you just about need a 4WD, to keep from tearing up the field, and so you have low range- it's sooo easy to go too fast and tear up the spreader.
rustyfarmall
01-16-2004 07:13:56
Yes, I pulled a John Deere model H spreader behind my 1963 Ford F-100 a few times, the truck was a 2 wheel drive so I was careful to not go where I may have become stuck. A neighbor pulled the same kind of spreader with his 4 wheel drive truck, worked very well. The one thing to keep in mind is that you can easily travel faster than what the spreaders were intended for, thus you could tear up and break things. Keep your speed down to what you would have with a tractor and you will be fine.
