If it's grass hay it sounds like you're about there by now. It depends on if you're putting up for cattle or horses. Cattle aren't as fussy. Horses can't have dusty hay and stay healthy. Grab some and twist it in your hands then release it. If it springs back that's a sign it's dry. Chew some of the wettest looking stuff. You should notice if it's still juicy. If so, roll that stuff to the top. Let it dry another half day or so and then try again. Usually I try to start putting ours up late in the morning when the dew is off, and I shut down around dark when the dew starts coming back. You just don't want to bale hay that is still wet. It'll rot or maybe heat and catch fire some hours or days later when it's in the barn. Conditioning or tedding can help keep the stuff fluffed up after mowing and get it more uniformly dry. Raking unconditioned hay several times as you imply helps, but it tends to knock leaves off. Enjoy the party.
