Hy-guard (Deere), Hy-Trans (IH) or Ambra (Ford)
John
02-20-2004 18:04:20
I am thinking of converting my Farmall H Lift-All over to regular Hydraulic oil from SAE 30, non-det. I am going to be using my JD 2 1/2 RC 1501 hydraulic cylinder (Which I got LOTS of help on this forum, AGAIN THANKS!!!!!). I was thinking of maybe using a regular type hydraulic oil in case I may sometime want to use the cylinder with my Ford 5600. I just changed my Ford 5600 hyd. oil to Ambra (Ford). Can I use Ambra in my Farmall H Lift-All? If I used Hy-Tran in my H, would using my Ford 5600 with the oil mixing be bad? Or should I just stick with using SAE 30, non-det. in my Farmall H and having a dedicated Cylinder like before? What about Hy-Guard (John Deere)? I seem to always have different pails of oil and would like to standardize if possible, Thanks!!
Don-Wi
02-21-2004 08:10:01
 Re: Hy-guard (Deere), Hy-Trans (IH) or Ambra (Fo in reply to John, 02-20-2004 18:04:20
The type of oil really shouldn't matter that much. If you look at the specs on the oil, it will probably state that it meets other company specs, like JD, CAT, Massey, etc... Really shouldn't be a problem to mix 2 types of oil if they're both hydraulic. Makes it a lot easier to buy one kind and use it in everything. Specially when you buy 55 gal. drums.
Donovan from Wisconsin
john
02-22-2004 17:24:09
 Re: Re: Hy-guard (Deere), Hy-Trans (IH) or Ambra in reply to Don-Wi, 02-21-2004 08:10:01
Thanks!!
