Can a one way cylinder work on a JD Plow?
John
02-23-2004 19:38:30
I have a John Deere plow (Not sure of the number) with 2 rubber tires in front, 1 solid tire in the rear and requires a Hydraulic Cylinder to raise it up. I was wondering if I can use a one way cylinder with it or will have to have a 2 way. I know that the plow will drop with its own weight but was wondering, when plowing ,will the plow ride up because the cylinder has no force the other way? Thanks.
John
02-24-2004 06:20:50
 Re: Can a one way cylinder work on a JD Plow? in reply to John, 02-23-2004 19:38:30
Thanks Guys!!!
JMS/MN
02-23-2004 22:05:37
A one-way cylinder is all you need. Plows are not pushed into the ground- the sharp plowshare is what pulls the plow into the ground. Years ago, I think it was IH that marketed a 'deep suck' share, designed to get decent penetration of the plow in hard to plow soils.
Curt P.
02-23-2004 20:01:32
A one-way cylinder should work fine. The way the moldboard is curved keeps the plow down with the weight of the soil as it's moving.
