Amateur Plow Question
John in PA
08-17-1999 04:16:29
After I get my rusty moldboard, shares and shims cleaned up and sharpened on my 1940 era plow, what do most folks use to preserve them between use?
I've seen where CT sells some spray can preservative for them, any experiences? WD40?
Gerald J.
08-17-1999 19:42:09
 Re: Amateur Plow Question in reply to John in PA, 08-17-1999 04:16:29
Been there, tried everything but WD-40...
If the plow is to be inside, used crankcase or transmission oil works fine. But it gathers dust, dirt, seeds, and bugs. Looks kind of bad but cleans up rapidly. Stringy wheel bearing grease works too, probably better than a modern gun grease, but still only inside.
I've been using CT soft coat on and off for a few years. Might not next year because it didn't keep the plow shares and moldboards from rusting on plow and plow parts sitting outside in central Iowa. Their red paint for MF red did a lot better a couple years back when I couldn't find my can of soft coat and a thunderstorm was approaching as I finished plowing. It kept the plow from rusting but didn't scour off rapidly. Though it had a fairly slick finish that dirt didn't stick to horribly bad.
Slip plate would be interesting, though I saw a couple gravity box bottoms that were new two years ago that where the slip plate was worn through and the steel was rusty.
I'll try to keep slip plate in mind since I have to keep some on hand for the planter drum seal anyway.
Gerald J.
Farmer Bob
08-23-1999 23:13:02
 Re: Re: Amateur Plow Question in reply to Gerald J., 08-17-1999 19:42:09
May be too late but...for years my Dad would smear what he called axle grease on the moldboard/share and colters of our plows. It was a very heavy, thick black grease that weather did not affect. Plows would sit out all winter and in spring, after pulling about 20 feet in the dirt all the grease was gone and parts were shiny (scowered).
You might try your local Cenex or Farm supply for the axle grease...it lasts forever. Smear it on with an old stiff paint brush and wear an old pair of gloves. Good luck!
John
08-19-1999 10:46:42
Seems everyone has their own favorites here with
no real consensus between "to lubricate" or "to
paint". I think I'll go with paint this first year and re-evaluate. This is a shed kept plow by
the way. Thanks to all who answered, should help
others, also. jhs
Gerald J.
08-19-1999 20:15:18
 Re: Re: Re: Amateur Plow Question in reply to John, 08-19-1999 10:46:42
If its inside, thick oil or grease is probably enough. On the other hand, applying spray paint keeps the hands cleaner than smearing grease or oil with bare hands...
Gerald J.
paul
08-24-1999 06:38:48
 Re: Re: Re: Re: Amateur Plow Question in reply to Gerald J., 08-19-1999 20:15:18
But paint is as hard to get off as the rust would be! :) I hope he didn't go overboard trying to clean the rust off the plow, if you have a sandy patch of ground it only takes 1 round.
I'd use the oil/grease, use an old paint brush. By the way, if you are into wood stoves, a gunny sack & ash will polish the plow shares the old fashoned way...
--->Paul
RickB.
08-17-1999 18:15:16
Over the years I have used Slip-Plate, Tilcoat and a couple other spendy sprays that work well, but the rest of any part can of aerosol paint lying around will do just as well, if not better in outdoor storage, and scours off fast enough to suit me. Medium gloss black looks real good, too.
john d
08-17-1999 13:52:21
I use slip-plate graphite paint. Got it by the gallon at a local farm supply store. Came in two grades, and I've used the heavy duty stuff with good results. It protects pretty well and polishes off easily when the plow goes into the ground. One advantage is that you can actually paint it over areas that have a little rust, and the paint will allow dirt to slide over those areas pretty well until it (and the rust) cut through and it all shines up.
VIC(Tx)
08-17-1999 12:55:50
Ihave read that a lot of old time farmers used linseed oil on all exposed metal or wood parts. Probably because it was cheap and makes a shiny finish. It might be worth a try because it couldnt be any more messy than lube oil or grease.
B.C.
08-17-1999 10:58:40
I would say grease would work okay if you had the thing under cover where it wouldn't get rained on. If it was outside, you might consider some Rustoleum primer. Not a lot, but a decent coat which should brush right off when you go plowing again, yet won't wash off in the rain.
RMD
08-17-1999 09:48:02
Paint it with drain oil.
JK MN
08-17-1999 08:38:59
John, That "soft" black protective coating is excellent. (comes in spray, quarts and gallons.) That is what the later new plows had as preservative. Easy to use and apply when the parts are nice and shiny. I used the spray, fast and easy to apply. I also used it on planter ground engaging part. Grease works well also, but is kinda messy. As for WD40, if you want something to do practically everday, it will work, just will not last very long.
jon a
08-17-1999 04:54:10
grease, smeared with a sufficent coat to cover all that will rust, keep plow inside of course when not in use.
just bought a plow for my tractor and now that I got it rust free, grease. good luck
Tom
08-29-1999 15:38:23
 Re: Re: Amateur Plow Question in reply to jon a, 08-17-1999 04:54:10
Burnt Diesel oil works best. Burnt gas oil will work pretty good too. Just paint it on w/ a brush after your last use of the plow for the season. I live in Southern Maryland so I don't get really bad winters but I've never had any trouble w/ my plows. Has soon has the plow goes in the ground it will shine like new. Even if you leave it outside.
