Cultipackers?
Adam
03-11-2004 17:42:14
I'm thinking about buying a cultipacker. I'd use it for planting clover and such for wildlife. I'd appreciate any info I could get (price range, good makes, bad makes, etc.). I've never seen one in the classifieds. Are they rare?
Jim
03-13-2004 17:55:28
 Re: Cultipackers? in reply to Adam, 03-11-2004 17:42:14
Well, I just bought a John Deere B10W for $50, and a John Deere F945H 12' just brought $375 on a local sale. Mine needed tires, one bearing, and a couple packer wheels and spring teeth, and the other was in near perfect condition. I would suggest either link on the bottom. There are several in the WI state farmer.
Leroy
03-12-2004 18:29:16
Jim and Cris are not talking cultipackers but cultimulchers, the cultimulchers are the ones with the teeth, a cultipacker does not have teeth, only rollers
jim
03-12-2004 10:47:21
Adam- I have a JD 915 culti-packer (two rows of solid wheel packers with "C" tine teeth in the middle.)In over 30 yrs, I've only replaced the points on the teeth and still have the original bearings. This machine has been over thousands of acres over those years and has been by far my best implement purchase. Very seldom do we lift it during turns, but we always set the tractor drawbar to fully swing and thus take most of the pressure off the bearings during the turn. This is a 12' machine and neighbours who bought the 15' model all had bearing problems for some reason.
Chris-se-ILL
03-12-2004 07:44:44
Leroy pretty much covered all the questions... {size/configuration questions} that need answered before you buy a cultipacker.
However, you may want to choose which sort of tines you want on the thing {"C" shank or Danish "S" shank}. I have two cultipackers that have the "C" shank and they are terrible for incorporating chemicals. The neighbor has one with "S" shanks, it incorporates well but it "balls-up" in heavy trash conditions.
Also, do you want a harrow dragging behind it? I have a "Remlinger" (spike-tooth) for one and a "Midwest" spring-tooth on the other. I like the Midwest... and took the Remlinger off {too heavy}.
A few things to remember if you get a cultipacker:
*NEVER, turn around at the ends (or even tight turns along edges) with the thing in the ground, or even barely dragging the ground {that's a good way to ruin the bearings}!
*NEVER, over-tighten the rollers (sliding them together on the shafts) to the point that you have one solid roller (with no endplay). There must be some movement (very slight freeplay) for each roller segment to just turn independently on the axle. Tightening them into one solid line of rollers is a good way to tear out an axle {each segment MUST have the ability to rotate at a different rate than the roller segment next to it...}.
Bad brand = Kewanee! Very poor quality of frame construction... Good rollers, everything else about them though is junk!
I have used my big cultipacker as a finishing tool to prepare clover/timothy filterstip plots, and for preparing alfalfa fields... works great!
Good Luck!
Chris-se-ILL
03-12-2004 07:48:37
 Re: Re: Cultipackers? in reply to Chris-se-ILL, 03-12-2004 07:44:44
You didn't say where you are from... there may be several cultipackers coming up for sale around here.
Adam
03-12-2004 10:14:31
 Re: Re: Re: Cultipackers? in reply to Chris-se-ILL, 03-12-2004 07:48:37
I live about 1 hr east of Eau Claire WI. Thanks for the input guys.
Leroy
03-12-2004 06:02:09
Common, Yes? bad brands, No? price, Size and location? $10 - $ 1500! Condition, all bolts tight, tight bearings, broken wheels, enough washers on axle to keep the wheels tight?
Leroy
03-12-2004 07:12:11
 Re: Re: Cultipackers? in reply to Leroy, 03-12-2004 06:02:09
Forgot to mention a few things. 4Ft or 35Ft? Light weight or heavy weight? Double roller or single roller or single roller with a sprocket type wheel between standard rollers? Last is Best for final firming of seedbed after planting, Heavy double best for crushing clods. Some wood bearings, some with roller bearings. Price, if it will do the job you want and do not have a backup one to go with then it is worth more, they are heavy so scrap price could be high.
Rick
03-12-2004 04:56:00
I have a parker brand unit. This unit is a disc mulcher. It has disc blades,then vibra tine shanks,then a large roller in back. You can work the ground a little more then seal it all n one pass. Have pic Can send if interested. It is for sale
