Bush hog tail wheel
L.C. Indiana
08-25-1999 09:53:07
How best to repair/replace tail wheel on bush hog? Axle looks o.k. but bearings are completely gone and now the wheel is more of a plow than a wheel. Replace just the bearings or the wheel assembly? Thanks, LC
paul armstrong
11-01-2002 06:29:21
 Re: Bush hog tail wheel in reply to L.C. Indiana, 08-25-1999 09:53:07
call hercules service parts at 1-800-566-8359
H. L. Staples
08-27-1999 17:57:53
If the inner and outer races of the bearings are still there or enough of them that you can read the numbers. you can get the bearings from a local bearing supply house or maybe an automotive store. or shaft and hub measurements will help to identify the parts needed probably need the grease seal also. Good Luck..H.L.S.
