Fast Hitch Mower Connect @ Other ?'s
Al L. in Wisc.
04-04-2004 12:42:28
third party image
I purchased a fast-hitch mower and when I lift it with my Farmall 340, the bottom of the sickle bar doesn't! What am I missing? Also, what model(s) do I have with serial #'s 451491-R7 and the other is 450874R3? Thanks in advance.
wolfy
04-04-2004 13:41:03
 Re: Fast Hitch Mower Connect @ Other ?'s in reply to Al L. in Wisc., 04-04-2004 12:42:28
Standing to rear of mower, look at the left side- you'll likely see a short lever. To the top of that lever, you need a short chain that attaches at the bottom of your hitch hydraulic cylinder; the Super C's used a long metal rod there that attached to the rockshaft up by gas tank that raised cutter with the touch control lever-precise, smooth nice set-up. Later Fast Hitch tractors without the rockshafts used the chain. As lift hitch, chain tightens, pulling lever that raises cutter bar.
Al L. in Wisc.
04-05-2004 14:17:20
 Re: Re: Fast Hitch Mower Connect @ Other ?'s in reply to wolfy, 04-04-2004 13:41:03
Green at this. I don't even know what a rockshaft is.
