SHREDDER / ROTARY CUTTER GEARBOX
Allen
11-16-1998 19:25:08
I was recently given a four foot rotary cutter/ shredder knowing it needed some work. The gearbox appears to have some teeth missing in the gears. You can rotate the shaft and get to a point where it wants to skip a tooth or slip. I haven't had it apart yet but was wondering if it is worth the trouble and money to try to fix. The cutter is structurally sound and is in descent shape all but the gearbox. The name plate says it was built by Mono Mfg. in Springfield Missouri. Any help would be greatly appreciated. Thanks Allen
Morris
11-19-1998 16:28:45
 Re: SHREDDER / ROTARY CUTTER GEARBOX in reply to Allen, 11-16-1998 19:25:08
: I was recently given a four foot rotary cutter/ shredder knowing it needed some work. The gearbox appears to have some teeth missing in the gears. You can rotate the shaft and get to a point where it wants to skip a tooth or slip. I haven't had it apart yet but was wondering if it is worth the trouble and money to try to fix. The cutter is structurally sound and is in descent shape all but the gearbox. The name plate says it was built by Mono Mfg. in Springfield Missouri. Any help would be greatly appreciated.
: Thanks Allen
This could be the same gear box that is used on some brand of round balers
