Farmall Cub Plow
Mike Knapp
09-03-1999 14:38:07
Hi,
I am having trouble with the plow on my 1956 Cub.
I seems to just skim over the surface instead of plowing. I have tried numerous height settings. Any ideas?
paul
09-03-1999 20:30:54
 Re: Farmall Cub Plow in reply to Mike Knapp, 09-03-1999 14:38:07
It often comes back to dull shares. Replace them.
Sometimes an older type plow needs some weight to balance it - like a 50lb rock.
Sometimes real dry clay ground is just about impossible to get a hold in.
Sometimes a plow needs to be tilted differently.
But if it worked before, it's probably wore down.
--->Paul
Gerald J
09-03-1999 15:38:48
Tilt it forward.
stew
09-03-1999 14:51:53
how are the points ??? new points will make a big difference if yours are worn,,,sometimes you don,t realize how worn yours are until you take a look at new ones
