Brush Hog Parts
C. Miles Benedi
09-06-1999 07:03:22
I have a FMC Sidewinder-5x5 brush hog mower. I'm looking for the part that is "dome" shaped that goes on the underside of the mowing deck and mounts to the steel bar that the blades are mounted on. I believe that this part protects the spline/shaft that comes down from the gear box to the steel bar that turns the blades. I'm sure this "dome" also acts to push the deck over rocks and stumps when mowing.
Can anyone tell me the name of this part and where I may find one in the Detroit, Michigan area? Thanks if you can offer any help or suggestions.
G. D CUMMINGS
07-19-2004 15:02:34
 Re: Brush Hog Parts in reply to C. Miles Benedict, 09-06-1999 07:03:22
I HAVE A WOLF BRUSH HOG, 4 FOOT SWATH AND I HAVE
SHEARED A PIN THAT IS SPRING LOADED AND HAS A LOCK WASHER ON IT. I NEED IT. CAN ANYONE TELL ME WHERE I CAN PURCHASE SAME.?
Dale
10-31-2002 20:27:49
The part is most often called a stump jumper, you can get a new one from Hercules Service Parts in Minden La. 1 800 566 8359
Wade
05-10-2002 17:58:24
I have several of these stump jumpers in my salvage yard,
Jimbo
09-06-1999 16:55:29
Sidewinder is out of business. The best source for parts would be Modern Mfg. in Beaumont, Tx..
The tire driven mowers are still manufactured by Gilcrest Mfg. in Holden, Mo..
Rufus
09-06-1999 08:48:40
All I ever heard it called is a stump jumper, or a stump guard. I couldn't find an equipment site for FMC. You are right it keeps the cross and blade from getting hung up on stumpsand big rocks.
