need a grass stick
51 Pony
06-13-2004 04:48:17
for the newly restored '51 MH field mower. I could make one myself if my lathe was long enough. I understand it needs to be 37" long, 1" diameter at the small end and 1-3/8" at the large end. Anyone have a great idea where to hunt one up?
51 Pony
06-14-2004 17:51:53
 Re: need a grass stick in reply to 51 Pony, 06-13-2004 04:48:17
Thank guys!
This mower hasn't been on the tractor in my memory (45 years). Dad grew up on a farm, but like some after the war, found diesel mechanics more interesting that butchering chickens. I have washed a few udders for my uncle however. I'm keeping the Pony running for Dad now that he's gone, and wanted to put some of the implements right before they faded away too much. The handle idea is the one I'll go with.
Chris Brown
06-13-2004 16:12:54
We always called that a finger board.
paul
06-13-2004 12:44:52
So, what's a grass stick?
--->Paul
TomH
06-13-2004 13:28:26
 Re: Re: need a grass stick in reply to paul, 06-13-2004 12:44:52
A stick, rod, or board at the end of a sickle mower the pushes the cut hay back into the swath. That keeps it from falling into the uncut hay and clogging on the next pass.
paul
06-13-2004 14:58:43
 Re: Re: Re: need a grass stick in reply to TomH, 06-13-2004 13:28:26
Windboard. Ok. Never saw a 'stick'', but a metal or wooden plate with a metal rod or 2 on it....
Thanks.
--->Paul
Mguy
06-13-2004 12:18:15
Pony, if you are using a sickle bar mower, you got something to do with livestock,and that means yer gonna have busted pitchfork around. Whack that sucker off square on the little end and on a pretty severe angle on the other end. There's your grass stick. Or see your FRIENDLY name brand dealer and FORK over some cash . Good Luck! Mguy.
Delbert
06-13-2004 11:12:52
Try a dowell rod, or spade handle, if not real picky go get a branch off of a tree about the size you want. Lots of them made with a hedge stick last a long time won,t rot or rust. Have used rebar.
Dave H (MI)
06-13-2004 07:39:36
Got a spoke shave?
ET
06-13-2004 05:14:09
I always found an old shovel handle worked well.
Dean K
06-13-2004 14:55:49
 Re: Re: need a grass stick in reply to ET, 06-13-2004 05:14:09
Closet pole is 1-3/8" diameter, and douglas fir if I remember correctly, probably have to sand the taper since it's pretty tough and stringy.
jCarroll
06-13-2004 19:48:57
 Re: Re: Re: need a grass stick in reply to Dean K, 06-13-2004 14:55:49
We made our replacements out of 5/16" steel rod. Then we could bend them to best handle whatever height of material we were cutting.
Don't get too fancy unless this is a parade mower.
