GANG MOWERS
Will Heveland
09-18-1999 21:32:17
I wanted to see if I could get some feedback on a set of gangs?What do they cost?How do they cut?And how is the upkeep on them? thank you Will
James O'Brien
08-27-2002 00:49:57
 Re: GANG MOWERS in reply to Will Heveland, 09-18-1999 21:32:17
I'm looking after a small field for football pitches. At present | cut it all with a small sit on mower but it can pull a small ganger. I live in Essex can anyone help??
James
TomH
09-19-1999 06:41:35
As always, the answer is "it depends". A little set that can be pulled behind a garden tractor is a few hundred (new). A big set like they use on golf courses would be $1000-1500 new, cut a little taller grass and tend to jam less.
They can cut a lot of grass quickly if the grass is kept fairly short and there are no trees around that drop sticks to jam it. You'll still need a rotary mower to get through thicker stuff.
The biggest complaint most people have is getting them sharpened; it takes special equipment that might involve hauling them somewhere and cost a bit, check that out before buying.
TomH
09-19-1999 06:37:29
