L59 WOODS MOWER
aaron morrison
08-15-2004 16:19:41
I HAVE A WOODS BELLY MOWER FOR A FARMALL A LOOKING FOR THE MOWER DRIVE BELT INSTALLATION ROUTING ANY HELP WOULD BE APPRECIATED
OLDMAN
08-17-2004 16:04:13
 Re: L59 WOODS MOWER in reply to aaron morrison, 08-15-2004 16:19:41
third party image
Here is a picture,it is the best i can do.hope it helps
Hilltopper
08-16-2004 17:28:44
I have the same machine I will try to help you. The belt goes over the pto drive pulley turns cw to line with top idler below then goes in front of and in the top groove of 3 stack pulley to front of right spindle pulley. back to rear side of center groove on center spindle around back to the front of left spindle, then around right side of center bottom groove through idler and no twist here it goes to back of pto pulley.
Sticker
08-15-2004 18:56:00
Had one, forgot how the belts went. There WAS a sticker on the deck that told what went where and how. A call to a dealer will work also.
Ohio-Bob
08-15-2004 17:24:00
might try www.woods.com at least you could contact them and ask for the info you need
