Brain is going dead for sure....Help!
Allan in NE
09-07-2004 14:19:48
Hi Guys,
A standard old everyday double acting hydraulic cylinder for differing pieces of machinery; I'm going out to buy a couple and now I can't even remember what size to buy.
Can't remember the size (4" x 21" retracted)?, the size of the ram (1")? (1 1/4")? Eyelet size?
Geeze, this is pretty bad 'cause I've been around 'em since forever and just never paid any attention their size.
What size cylinders do you guys use?
Thanks,
Allan
Steve(OR)
09-07-2004 15:16:33
 Re: Brain is going dead for sure....Help! in reply to Allan in NE, 09-07-2004 14:19:48
Is there a "standard" size? I would have thought that it depends on the specific application - weight lifted, length of extension, hyds pressure and volume available, etc. Just curious.
Allan in NE
09-07-2004 16:31:18
 Re: Brain is going dead for sure....Help! in reply to Steve(OR), 09-07-2004 15:16:33
Hi Steve,
Probably not anymore in this day and age; I'm finding everything is different! Enter: 4 wheel drive tractors, $40K pickups and goose-neck trailers. (but, this is a whole 'nother chapter)
Okay, so now I'm in the process of loading back up again and my mind is still stuck back in the eighties when I was forced to sell out.
Everything on the place used the same relative sized cylinders, from the corn head on the chopper to the lift cylinders on the discs & packers to the spin cylinders on the plows to the haying equipment. They were all pretty much the same size.
I think, as these other fellas have said, that what I want is the common "3x8" things.
But, what I won't have is a dag-gonned 4 wheel drive tractor!.....oooops sorry, wrong rant. :>)
Thanks all,
Allan
Indydirtfarmer
09-07-2004 15:45:40
The 8" stroke is fairly standard. Almost all my equipment uses 8". Small equipment can use small bore cylinders. (1-1/2" to 2") Bigger equipment on a bigger tractor will use bigger cylinders. (2-1/2", 3", an on up to 4" bore) Most of mine are 8" x 3". John
kyhayman
09-07-2004 17:50:27
 Re: Brain is going dead for sure....Help! in reply to Indydirtfarmer, 09-07-2004 15:45:40
Mine too.
JMS/MN
09-07-2004 14:29:12
Typical cylinder to lift a planter, drill, cult, plow, etc. is an eight inch stroke, two or three inch diameter. Even my six bottom IH plow has only a 3x8. Eyelet size is generally one inch.
