Bush hog for C model allis chalmer
ttrammel
12-01-1998 23:10:49
i have a 1949 "C" model allis chalmer without a three point hitch. what type bush hog would work with it?
Rob
12-03-1998 15:46:57
 Re: bush hog for C model allis chalmer in reply to ttrammel, 12-01-1998 23:10:49
ttrammel,
I have a 5' Bushhog brand finish mower. I run it on a Ford 8N. I don't have to lift it to travel anywhere. I have decided to make some bars to bolt with angle onto the hitch of my Allis B, and weld on some repair balls to simulate the lower arms of the 3pt. I don't use the top link on the Ford when mowing. Only chains to lock it at the right height. I think the Hp is about the same so it should work fine. Once that is proven I will probably build a 3pt hitch for it. I know that several aftermarket 3pt are made for the B and C. $400 is a lot but, if you need to change and/or carry implements a lot it may be worth it. You can find conversion kits at this site. they will give you some ideas of what is required.
Good luck!
Rob
