massey loader
67ssimpala
10-20-2004 21:15:21
I"m wondering how I find out whether I have a massey loader on my 8N. I was told that the loader is a davis loader. Are they the same thing? Does this loader have a specific model number, and if so how do I find out what model it is? I NEED to get a hydraulic filter for it and there was not one in it when I bought the tractor.
Thanks!!
Don-Wi
10-21-2004 19:28:53
 Re: massey loader in reply to 67ssimpala, 10-20-2004 21:15:21
You should be able to pick up a filter assembly at your local TSC, Fleet Farm, Farm & Fleet or other similar stores. Unless you only have warm weather, put it after the pump. Trying to pull thick cold oil through a filter isn't a pump's favorite thing to do. My 165 absolutely wouldn't pull it through a 10 micron filter. Now I run w/out a filter w/out any problems. I run off the rear end of the tractor and pull it all the way up to a pump on the crankshaft. Donovan from Wisconsin
old
10-21-2004 08:29:07
I'd put what is called 303 universal hydarlic fluid in it. Covers just about all the companys recomedations. Massy, Ford, JD,Oliver,Farmall,Case, and CAt
