Front or rear blade for snow?
Brian
10-27-1999 18:31:01
I am preparing my new (to me) Farmall 140 for the winter season. I mounted the front snow blade that I got with it and I also have a nice back blade.
I hear that the front blade will reduce traction and I believe it. The front blade has no shoes so I have to hold it up with the hydraulics and the level seems more difficult to set than the rear blade.
Is there anyone out there that has both blades and can tell me if there is an advantage to using the front blade, or should I just mount up the back blade and wait for snow?
Thanks.
Tim (UT)
12-06-1999 14:40:16
 Re: Front or rear blade for snow? in reply to Brian, 10-27-1999 18:31:01
Well, it depends. If you don't get much snow at any given time, then the back blade will you (that's what I use).
The front blade nice if you have lots of snow, but as you've already seen, it can push around the front of the tractor. If your tractor has individual steering brakes, you can use them to help keep it headed in the right direction.
A front blade without some kind of skids is also going to be a challenge for moving snow - especially if the ground isn't frozen good and/or you have cement that isn't completely flat.
Tim
