AGMO Rotary Cutter
BHG
10-29-1999 09:36:00
I am working on a rotary cutter for my aunt. It is a 4 foot cutter and the name and number on the gearbox is AGMO R-45-312. Does anyone know where I can get a seal for the vertical shaft?I can't seem to find anyone locally who can help. Is this company still in business? Or is this a model name in a company's line of cutters?
Thanks in advance.
Edwin Rodriguez
07-22-2005 14:05:21
 Re: AGMO Rotary Cutter in reply to BHG, 10-29-1999 09:36:00
TO BHG
I have a mower with the sam S# were did you parts for it ? And did you find out when and who made them ?
Thanks ERR
Brian Oordt
06-18-2003 21:45:46
I'am looking for a gear box for an AGMO 5' rotary cutter. The number on mine is S45-312. I would like to know if you found any parts.
B. A. Brown
07-14-2003 19:07:15
 Re: Re: AGMO Rotary Cutter in reply to Brian Oordt, 06-18-2003 21:45:46
I also have an AGMO and the number is S45312.. I need to know how to drain the gearbox fluid. I found the filler hole, and the allen wrench level hole, but not the drain hole.. If you can help I would appreciate it very much. How old are these units? This really belongs to my sister inlaw, but I do all of her mowing since her husband died. Thanks for your help.
B.A. Brown
John
08-09-2003 07:44:36
 Re: Re: Re: AGMO Rotary Cutter in reply to B. A. Brown , 07-14-2003 19:07:15
You need to check out Howse Implement Co. They build equipment here in Mississippi and use AGMO gear boxes. They should have all the parts you need. They have a good web site with all part #'s and prices.
