Hi Mike, You're welcome. There aren't many of us left. Thousands of acres around here have been 'developed' for houses. Seems like it used to be a good idea to grow food close to cities. It turns out David was up north snowshoeing. He does have a Stanhay. He uses it for everything except corn, beans, and peas. He thought that the belts and bottom plate might be too thin to handle big seeds. A Dwarf Gray Sugar seed might be small enough to work. Beets work fine. Pelleted carrots make perfect rows- good germination, a uniform stand, and no thinning. The thing that he likes the best about it can plant bands (i.e 2 rows 2" apart) in addition to a single row. Weeds in between the two can be a problem if the crop does not canopy right away. David said that everyone that he talked to is only using their Stanhay for carrots. It does have a hard time with any oblong seed, but pelleted works fine. The cost was about $1000 for the unit and the plain belts are $30, Punched belts (if you tell them the size and spacing) are $40, and if you send them the seed, have them punch the belts and test them, they are about $60. I think that the 71s would do pelleted lettuce to corn, but you would need different hoppers or at least different hopper bottoms. I am thinking about setting up two units on a tool bar for corn and beans. Then I'll park my 290 and Planet Jrs for good. FYI if I remember correctly I paid $650 for a 9 row unit. It was about the same price to buy the whole thing than just 4 planters. With a 9 tooth drive sprocket, a 22 tooth driven sprocket and a 36 cell plate you would get a seed spacing of 8 1/2". Lincoln Ag has blank, 36, and 72 cell plates in various thicknesses. The cut off in the hopper will literally cut off any seed sticking out above the plate. If you would like, I can post a picture of the sprocket / seed spacing chart. The 71 manual is JD part number OM-A41062-C0. I think I found mine on eBay. Greg
