Herd Seeder--Mayday---Mayday
Jerry
11-07-1999 10:48:28
Anybody know the settings for a Herd Seeder for fescue and timothy? I've lost my chart and the decals have long been fallen off the seeder.
Thanks for any info.
Jerry
Tim(nj)
11-08-1999 18:44:34
 Re: Herd Seeder--Mayday---Mayday in reply to Jerry, 11-07-1999 10:48:28
You've got a problem. The settings are different for different models of Herd seeders. So if you don't know what model it is, tracking down the right setting is going to be hard to do. The decal on my M-96 has settings for several other models, so if you have even a vague idea what you've got, I might be able to help.
Jerry
11-09-1999 17:39:14
 Re: Re: Herd Seeder--Mayday---Mayday in reply to Tim(nj), 11-08-1999 18:44:34
Thanks Tim I think it's a 750. I looked at a Herd manual today it didn't have any settings in it, but ours looks like the 750.
bbott
11-10-1999 19:24:06
 Re: Re: Re: Herd Seeder--Mayday---Mayday in reply to Jerry, 11-09-1999 17:39:14
I've got the original HERD decals from my spreader transcribed into a M$ Word document.
If you want, email me and I'll bounce them to you... (the address on your posting puked)
For a 750 for Fescue & RyeGrass.... (24lb/bu)
Spread Width ----- --- 18'
Amt/Acre ----- ----- ----- 9.4 lbs
Opening Width ----- -- 1/4"
Tractor Speed ----- --- 8 mph
Time Per Acre ----- --- 3min 28sec
Tim(nj)
11-11-1999 19:33:45
 Re: Re: Re: Re: Herd Seeder--Mayday---Mayday in reply to bbott, 11-10-1999 19:24:06
My chart confirms this. However, I can't find a listing for timothy. I've done it with the M-96, but it only spreads about 10' patterns, and the lowest rate I've been able to get before the gate starts plugging up is 15 lbs at a 1/4" opening, 6 mph. Of course, that's an estimate. A 750 would probably give similar results. One thing I've noticed when spreading timothy is you can't see it coming out! Check your hopper level every couple of rounds to see if you're getting the right rate. I try to put timothy on with my drill's grass seeder box whenever possible, for accuracy.
Jerry
11-12-1999 17:44:55
 Re: Re: Re: Re: Re: Herd Seeder--Mayday---Mayday in reply to Tim(nj), 11-11-1999 19:33:45
Thanks Tim- I never thought about the timothy problem. This is my 1st time to have to plant it.
I will broadcast the other seed and drill the timothy in. I always run back over with a roller anyhow.
Jerry
11-11-1999 16:31:20
Thanks bbott- I emailed you some another email address.
