3pt ford bar rake
allis 5040
02-14-2005 20:14:01
A man I work with has a pto driven 3pt bar rake for sale cheap. What are their problems?
allis 5040
02-15-2005 19:29:51
 Re: 3pt ford bar rake in reply to allis 5040, 02-14-2005 20:14:01
Thanks to all for their replies. Owner wants $100 for the rake says it needs a new drive belt.
JiminIA
02-15-2005 15:59:28
We had one, i thouhgt it worked good because you could just pick it up when you got the end of a row or the center of the field. Once in awhile in real heavy hay the rotating bar would wrap up but not to often. I wouldn't mind having another one again.The caster wheels on the back would rotate to far and get hit by the rake teeth every so often, until we made a stop....Jim
Ultradog MN
02-15-2005 05:57:12
I can't tell you if they were any good or not but if it is an older red Dearborn implement it would be worth something to collectors of older Ford stuff. There weren't a lot of them made and all of that older Ford/Dearborn stuff is getting to be be pricey. You might make a nickel on it just by buying it and putting it on Ebay or YTMAG auction.
Good luck
Jerry
paul
02-15-2005 05:24:31
They were not popular around here, can only repeat what the neighborhood says, as I've never seen one work in person....
A bit of work to hook up, then you need to run at one speed, whatever matches up to ground vs pto speed. About the only implement a ground-speed pto is a good thing. :)
Tend to run a little too fast, beat the leaves off alfalfa.
Again, just what I hear from around the area, could be all wet.
--->Paul
James in NC
02-15-2005 05:51:53
 Re: 3pt ford bar rake in reply to paul, 02-15-2005 05:24:31
Make sure that the counter rotating bar up front is in good condition.
