3-bottom pull-type plow for JD A
Mike
11-09-1999 15:13:27
Does anyone have any info on Model numbers and Manufacturers of 2 and 3 bottom plows. I need one for my 47 JD A. Websites?
Ronnie
11-11-1999 19:22:38
 Re: 3-bottom pull-type plow for JD A in reply to Mike, 11-09-1999 15:13:27
Mike read my the post under larry h name. goof
larry h
11-09-1999 16:26:50
the best plow for all around use and easy to get parts for is an oliver wheel or hyd lift they will also pull a lot easier than the other brands they will still be fairly reasonable to buywe use them at our show and work day every year
Ronnie
11-11-1999 19:18:04
 Re: Re: 3-bottom pull-type plow for JD A in reply to larry h , 11-09-1999 16:26:50
I just traded a JD 3x16 plow off for a IH 4x14. The JD plow will be for sale let me know and I'll give you the man name.
larry h
11-09-1999 16:25:08
larry h
11-09-1999 16:23:52
