Super A one bottom plow
AZglide
04-11-2005 15:57:11
I picked up a one bottom plow the other day that has the numbers IH512504R1 stamped in the main beam. I looked through the archives but didn't see much information there. Can someone tell me the model of this plow. Also, I've seen this type of plow on a cub before but not on a Super A or 140. Think I remember there being a chain that ran from the beam to a bracket bolted to the right axle housing (not the lift chain) and a lever to adjust the drawbar height. Are these necessary on a 140? As usual, thanks in advance.
Robert Drake
03-10-2006 03:30:43
 Re: Super A one bottom plow in reply to AZglide, 04-11-2005 15:57:11
The plow you have is an A-189 one bottom two way plow. With the number you gave it is the right hand plow. There was a left hand and right hand plow> The left hand was stamped 512503R1 on the beam. This plow had a bracket that bolted to the drawbar in the front position. It had a bar that mounted from the drawbar to the right hydraulic touch control arm to control the deep of the plow. There was a chain hook that mounted to the rear rockshaft that hooked to the chain on the plow beam to raise and lower plow.
