bottom belts for a 510 John Deere
Ain't baling ha
04-14-2005 02:35:01
I need new bottom belts for an old 510 Deere. Is there an aftermarket place that deals in these so I won't have to get screwed at the dealer?
Also, has anyone ever spliced these belts? I know there's a lot of pressure on them when the bales is being formed....
but it sure would be easier to fix without taking the rollers and pickup out.
Thanks,
paul
04-14-2005 15:36:30
 Re: bottom belts for a 510 John Deere in reply to Ain't baling hay...., 04-14-2005 02:35:01
Shoup has all kinds of baler belts - I run a different color so don't know what they carry for you, but would be worth a look. They are online, but the print catalog is much better than the online version.
(PS: Looks like they have an 8" endless for $80 if that is what you need?)
--->Paul
JiminIA
04-14-2005 09:53:25
They could be tough to splice. Where are you located? I can check to see whats available aftermarket if you would like me to. E-mail is open....Jim
ChrisL
04-14-2005 04:37:02
my old IH 241 has a spliced bottom belt - old style splice - but it came that way - don't know who did it or where it came from
Tx Jim
04-14-2005 04:22:29
I've never seen a splice tool made for a belt as wide as one in bottom of 510.You would have to do several tries for one belt.It may be difficult to get space between each correct.If I were going to attempt splicing lower belt I would use newer type splice.IMHO the newer splice is far superior to the old splice.Jim
ain't baling hay
04-18-2005 05:05:46
 Re: bottom belts for a 510 John Deere in reply to Tx Jim, 04-14-2005 04:22:29
Thanks for all the insights fellers. They are available from JD for $120 a piece. Shoup has them for $80. I'll probably just buy them and save myself the headache.
