Pumpkin PLates
Adam S
04-24-2005 20:01:21
Hi, I was wondering if anyone knew where I could find a set of planter plates that would plant pumpkin seeds. I am currently using the John Deere lustran planter plates to plant sweet corn, and I now am needing a set of pumpkin plates or a set of plates with really big holes in them. Thanks to everyone in advance.
John e.c.MI
04-25-2005 04:51:51
 Re: Pumpkin PLates in reply to Adam S, 04-24-2005 20:01:21
Deere has a pumpkin plate. It is a 12 cell plate but you also have to get a special ring that goes with the plate and sits under it in the hopper. We found that with our planter it would drop the seed too close together no matter what sprocket combination we used. This is on a one row JD 71 planter. To fix this we got a plastic 'blank' plate, used JD's plate as a pattern and used a die grinder to cut four cells in the plastic plate. This gave us the seed spacing we were looking for.
