Drew, I don't know anything about your plow nor what tractor you are using. Also, you didn't say how wide a cut you are taking. All things being equal, that plow wants to go straight ahead unless it's frame is sprung in some way. If the frame of the plow is not damaged, the problem lies in the way you have the tractor set up. My gut tells me that you have the stance on the tires wrong, like Hugh says. "The right tractor wheel is in all the way." just doesn't sound right to me. It sounds as though you are trying to cheat that front bottom out of real estate and it is pulling left tryin' to gain more "row". Also, here are some things to think about. The worst thing you can do is try to "force" the plow to go where you want by fiddlin' with that silly 3-point. When it is pulling true, the only thing that even enters the equation is the pull at the lower links and even that is just a forward direction tug; just as if you were pulling with a drawbar. You should be able to take that top link completely off the tractor and throw it away, because you don't need again until you lift the plow out of the ground; that is all the top link is used for. Do you have the collars dropped down on the lift links so that the plow can run true laterally? This one is in the 'up' position. For plowing, it needs to be lowered to the bottom dimple. This lets it 'float' and will allow for the furrow depth difference. Hope ya get 'er, Allan
