Case moldboard plow
David
12-01-1999 18:27:40
I need help, I have a Case plow which has two 14" moldboards. It has CASE stamped on each main piece of frame that the plow shers mount. I have looked all over it and can not find a model. It is painted sort of an Oliver green, I don't know if this is correct. Where is the data plate if there is one and what color is correct.
Al
12-05-1999 17:01:03
 Re: Case moldboard plow in reply to David, 12-01-1999 18:27:40
Your plow is probably a Case Centennial plow. They were built from the late thirties until the early fifties. They had a green frame and orange moldboards. Later ones had an orange and green frame. There is no identification tag on them.
wayne
12-02-1999 02:29:18
Can't be of much help to you. The older Case machinery had some green paint. These old Case plows pulled one hell of a lot harder than their competitors.
Ronnie
12-02-1999 19:07:59
 Re: Re: Case moldboard plow in reply to wayne, 12-02-1999 02:29:18
Harder than what plows? I have a four bottom case pull type plow and I thought it pulled just fine.
paul
12-02-1999 19:17:47
 Re: Re: Re: Case moldboard plow in reply to Ronnie, 12-02-1999 19:07:59
Oliver is well thought of around here, followed by JD.
--->Paul
Ronnie
12-04-1999 07:06:26
 Re: Re: Re: Re: Case moldboard plow in reply to paul, 12-02-1999 19:17:47
Oliver I have pulled and thought they were the easyest pulling plow. John Deere pull like a rock. I traded a 3x16 JD for a IH 4x14 the 4 bottom pulls easyer. I have a 4x14 Case that I like too. All plows are pull type and hydralic lifts.
Computer said to try again later so I did (Ronnie)
12-04-1999 07:09:50
 Re: Re: Re: Re: Re: Case moldboard plow in reply to Ronnie, 12-04-1999 07:06:26
Ronnie
12-04-1999 07:05:40
Ronnie
12-04-1999 07:03:20
highboyford
12-02-1999 16:26:41
He is right moldboards were a nice dark green,and like a case nut of a friend once said "it takes a case tractor to pull a case plow"I dont know if that part is true or not but boy do they pull hard.Last case plows were built to case specs by oliver corp.
Tim(nj)
12-02-1999 20:02:46
 Re: Re: Re: Case moldboard plow in reply to highboyford, 12-02-1999 16:26:41
Built to Case specs but using the easier pulling Oliver style bottom. Ford plows from around 1980 on were the same way . . .
highboyford
12-05-1999 16:13:42
 Re: Re: Re: Re: Case moldboard plow in reply to Tim(nj), 12-02-1999 20:02:46
We had a brand new on land hitch Case plow in 1978 had factory reps out to look at could not pull it with a case 2470 or 2670 both would just spin the wheels or bounce even with fluid in the wheels finally traded it for a D.M.I which happens to run oliver bottoms also.That way at the time we could carry bottoms for every plow we owned.
highboyford
12-02-1999 16:24:40
