52 Super C Implements
Rich in MD
12-08-1999 04:26:31
I am new to this and I am in the process of buying a 52 Farmall Super C. I was wondering what implements could be used with this particular tractor. It appears to have a 2 - point hitch system with a draw bar. Are all available implements going to be belly mounted? I am interested in snow removal and small garden plowing with it. Any assistance or insight would be appreciated.
MrG:
12-08-1999 13:45:23
 Re: 52 Super C Implements in reply to Rich in MD, 12-08-1999 04:26:31
What you have on the back of your C is, as FM has pointed out, a 2pt "fast-hitch". I have just such and animal on my IH350U, but my mower, blade, and toolbar are all class I and II 3pt tools. What to do? What to do?
Solution: Worksaver (on the web) has heavy bars with a ball socket (that swivels to accept either a class I or class II pin). These snap directly into the fasthitch lift arms. They also have a plat that bolts high and centrally located above you PTO shaft to mount the required 3rd link.
I have seen the ball socket lift arm extensions at TSC also, but you will probably have to do a bit of Southern engineering to make up a third link bracket.
For tractors (such as my 560) that do not have a "fast-hitch", both worksaver and saginaw have complete axle mounted add-on three pt systems.
3pt is the way to go to use commercially available new implements. This setup also does not preclude you from pulling the lower lift arm extensions and using true fast-hitch implements, should manage to acquire something at a sale somewheres.
FM
12-08-1999 12:35:07
try these guys. they have a few implements for the Super C. Blade is one I know of, might have a plow for teh Fasthitch(the 2 point lift mechanizm)
Rich in MD
12-09-1999 05:34:15
 Re: Re: 52 Super C Implements in reply to FM, 12-08-1999 12:35:07
Thanks for all of your insights. I have since posted another question in reference to the two point hitch system and the fast hitch. Any insight that could be shed for this newcomer? Again, thanks to both of you.
