Burrhead, I read where you have used the TSC 60 gal PTO Roller Pump. Let me run this by you and you tell me if will work. I have a few wooded acres with spots of Mother of Millions, a type of noxious(sp) weed here in Australia. I have been using a back pack sprayer but looking for something easier. My idea is to mount a 44 gal drum on a cart behind my tractor, install the PTO pump, run the 12' - 15' pick up from the pump to the drum holding the herbacide, then on the ouput side of the pump essentially run a 50' garden hose to do the spraying with. I'm still going to do the sparying of foot because of the trees, but at least I want be wearing the back-pack. Will this work? I'm assuming that as long as I have the pick-up line below the herbacide level that the pump will pick-it up (ie that the drum holding the herbacide does not have to be pressurized), am I right about this?? Thanks, Ted
