Hardee Rotary Cutter
Russ Gregory
12-10-1999 03:59:13
I have a six foot Hardee Rotary Cutter (Model T-872-LTFR) that has a leaking gearbox bearing seal. Where can I get parts for this thing.
Hardee Equipment sold out to somebody several years ago, does anybody know who?
Does anyone else have this size cutter? I've had mine for about six or seven years. This is the first maintance I've had to do on it, and I've beat the tar out of it cutting four to five inch pine trees and other things its not designed to cut. I've found that if I can run over it with the tractor, this thing will cut it up. Sometimes, I may have to drop into Low-Low gear and even ride the cluch to slow the forward speed. Its a very good peice of equipment.
krue
09-05-2006 12:11:33
 Re: Hardee Rotary Cutter in reply to Russ Gregory, 12-10-1999 03:59:13
Try Link
Jimbo
12-10-1999 09:28:08
Hardee is now owned by a company called Williams Controls. I know of a dealer in Arkansas, if that helps let me know and I'll give you his phone no..
