Bottom belts on 510 JD baler
Alberta Wayne
07-07-2005 07:55:50
Just wondering if anybody has tried using lace-up belts on the bottom of a 510 John Deere baler. Manual says to use continuous belts but the machine has to be dissmantled to change them out. If it would work I would like to try lace-up belts. Thanks Wayne
randy grider
06-01-2006 19:51:27
 Re: Bottom belts on 510 JD baler in reply to Alberta Wayne, 07-07-2005 07:55:50
have not looked at my 410, how much trouble is it to replace the bottom belts? would the newer diamond tread design work more efficiently?
Mike in Houston
07-07-2005 16:01:05
I had to put belts on the bottom of a 510 I had. Was thinking the same as you. Talked to a belt supplier and he told me that alot of people he sold those belts to put on lace type and they worked ok for them. I went with endless though. Didn't want to stray away from design.
Good luck and be safe.
mee
BradS
07-07-2005 13:11:39
I put lace type belts on my old John Deere 410 baler and they worked fine, Make sure they are adjusted to run straight
ChrisLSD
07-07-2005 08:44:18
I have an IH 241 Bigroll - same era baler - it has a wide (entire width of baler belt on bottom) - mine is laced - was that way when i got it - works OK
