Ford Model 14-93 Mower question
Al B
08-05-2005 09:45:25
I just bought an old 14-93 Ford sickle mower for my 860. The problem is, I can't get the sickle bar level. When I raise up the 3-point all the way, the other end of the sickle bar is still on the ground. It looks as though it may be set to cut ditches(?). Is there an adjustment I can set to level out the sickle bar?
Jerry D in NC
08-05-2005 12:43:46
 Re: Ford Model 14-93 Mower question in reply to Al B, 08-05-2005 09:45:25
Is the clamp on the left lift arm attached???
paul
08-05-2005 22:22:21
 Re: Ford Model 14-93 Mower question in reply to Jerry D in NC, 08-05-2005 12:43:46
Yea, this is the same as a Ford 501 mower. It should have a little arm coming off the bottom of the left frame. This clamps to the tractor's left 3pt arm. You can slide the clamp forward so the bar doesn't raise as high, or rear-ward so it raises higher.
--->Paul
Don Anderson
01-31-2006 10:32:46
 Re: Ford Model 14-93 Mower question in reply to paul, 08-05-2005 22:22:21
What is the length and size of the pitman arm?
