CIH 2 btm plow on steel
Aaron H
09-29-2005 20:01:30
I want to repaint dads plow, Not sure what year, I need to see one to know the paint scheme. Can anyone help?? TIA
Hugh MacKay
10-01-2005 01:36:22
 Re: CIH 2 btm plow on steel in reply to Aaron H, 09-29-2005 20:01:30
Aaron: Your question is a bit confusing as CIH have never built a trailer plow on steel. It is quite clear however, you are talking about a plow built by one of the parrent companies, being either Case or IH.
If the plow is IH my guess is, Rusty's photo has probably nailed it for you. He did leave out one little detail on that tail wheel as some of the Little Wonder plows did have a tail wheel. The difference being, the Little Wonder tail wheel was fixed in one position, whereas on the Little Genius the tail wheel has a linkage from front wheel rockshaft and tail wheel lifts and lowers back of plow. That linkage can be seen on Rusty's photo if you look closely.
Jeff Wenner
09-30-2005 09:18:20
Go to this link, it is a Little Genius Tractor Plow
http://www.wisconsinhistory.org/libraryarchives/ihc/paint/display.asp?pageurl=037_01.gif
Leroy
09-30-2005 05:59:20
Are you talking IHC or Case? Big difference tho now both companys are part of CIH and your post indicates you do not know the make by listing it as CIH.
RustyFarmall
09-30-2005 04:47:03
Are you talking about the little genius plow or the older little wonder? Does it have a tail wheel?
Aaron H
09-30-2005 05:38:11
 Re: CIH 2 btm plow on steel in reply to RustyFarmall, 09-30-2005 04:47:03
It is a trip plow with a tail wheel.
RustyFarmall
09-30-2005 11:41:44
 Re: CIH 2 btm plow on steel in reply to Aaron H, 09-30-2005 05:38:11
third party image
Like this one?
buss
10-05-2005 06:35:58
 Re: CIH 2 btm plow on steel in reply to RustyFarmall, 09-30-2005 11:41:44
what are the color names or nos. thank you my barber has been wondering
RegularRog
09-30-2005 14:29:33
AWESOME!!!
