David Bradley two bottom plow
Dana
01-02-2000 08:56:24
Does anyone know anything about a david bradley two bottom plow? any info would be of help.
thanks
Tinker
01-05-2000 01:18:46
 Re: David Bradley two bottom plow in reply to Dana, 01-02-2000 08:56:24
David Bradley was sold by Sears, and you probably won't be able to get any repair parts through them, as they don't tend to carry parts for anything that old. If you need parts, you'll have to try your luck at matching something up at a place like Tractor Supply.
Fudd
01-02-2000 17:24:12
Sorry I can't give you an technical info but we had a David Bradley plow back in the 50's and early 60's. We plowed many many acres with that plow and it worked great. My Dad was always fussy about his plowed ground and always insisted nothing stuck up through the ground after plowing. If it was corn or grass or hay it had to be completely covered. That plow always did the job as he wanted. You have to remember this was in the days the disks were not all that great. Sears sold the David Bradley line back in those days. Good Luck!
