NH hayliner 68 baler
55 50
10-16-2005 22:22:40
Am working on this baler to get it in running order. It has been sitting for about 10 years, mostly inside. After some greasing, oiling and gentle turning of parts by hand, I've got everything free except the plunger. It moves part way, but still doesn't want to make a full turn. I have the main chain off so just the plunger moves when I turn the flywheel by hand. Anyone have a "sure way" to get the plunger freed up? I know I'll have to re-time things but I have a manual and that explains the timing process. Thanks for your help.
Our Farmer
10-17-2005 14:41:54
 Re: NH hayliner 68 baler in reply to 55 50, 10-16-2005 22:22:40
Before I tried forcing it I'd try and "grease the skids" with some wd 40 or other penetrating oil. I'd also loosen the track adjusters to make sure the rust on the guides don't wedge the plunger in there in tighter. If you've got the chain off, and the stop block wedged open, there's no reason she shouldn't turn.
Course if I were feeling real lucky, I'd hook her up and try turning her with the tractor PTO, see if I could get a little momentum working for me. Make sure the needles are all the way home before you try it!
55 50
10-17-2005 18:45:56
 Re: NH hayliner 68 baler in reply to Our Farmer, 10-17-2005 14:41:54
Our Farmer, Thanks. I"ll loosen the track adjusters next.
KEH
10-17-2005 04:56:10
Is plunger lock tripped and catching the plunger?
KEH
55 50
10-17-2005 07:28:46
 Re: NH hayliner 68 baler in reply to KEH, 10-17-2005 04:56:10
I have that lock blocked with a board so it's not catching that. The plunger doesn't get that far back before it binds. I'm pretty sure it's binding from the rust and dirt packed in the tracks it moves in. I've vacuumed some of the lose stuff out of the tracks but it still binds. Would it be safe to hook a type of puller on and gently force it?
TimS
10-19-2005 13:52:39
 Re: NH hayliner 68 baler in reply to 55 50, 10-17-2005 07:28:46
Take a putty knife and scrape the dirt and old hay chaff out of there, then grease up the tracks good and try that.
TimS
10-19-2005 13:42:34
Rexalot
10-27-2005 12:45:40
 Re: NH hayliner 68 baler in reply to TimS, 10-19-2005 13:42:34
If it's not a "super" model then the plunger is riding on wood bearings (strips of white oak). If so, the plunger itself wouldn't be the problem.
If it is a super series you very well might have a frozen or non-existant roller. You should be able to view these from the bottom of the bale chamber.
55 50
10-28-2005 21:04:05
 Re: NH hayliner 68 baler in reply to Rexalot, 10-27-2005 12:45:40
It's not a "super" model so it does have the wood bearings. Would you please expand a little on your statement "the plunger itself wouldn't be the problem". Thanks
55 50
10-28-2005 21:01:02
It"s not a "super" model so it does have the wood bearings. Would you please expand a little on your statement "the plunger itself wouldn"t be the problem". Thanks
55 50
10-28-2005 20:58:33
