Henderson Manure Loader
RandyW
01-02-2000 15:16:12
I have a 1947 AC "C" with a Henderson Manure Loader on the front. This uses a separate hydraulic pump and reservoir which attaches to the PTO shaft. Does anyone have any information on this, specifically, what type of oil should I use in it. Or is there an easy way to test what is already in it to determine if it is motor oil, hydraulic fluid, or what?
Wayne
01-02-2000 16:20:33
 Re: Henderson Manure Loader in reply to RandyW, 01-02-2000 15:16:12
You can use hyd. oil or non detegent motor oil in it. 10w winter and 30w summer. Also you could add a filter to keep the chunks out of the pump.
