2- cyl JD MT cylinder compression tests
tom
02-13-2003 05:51:05
Howdy,
I can not locate the cylinder-head compression ratios lbs/psi in any of my manuals. Does anyone know (1) what the heads should test? (2) an acceptable tolerance range? (3) any differences from head 1 or head 2? and (4) any special thing I need to look for or do when testing the cyl-head compression?
Thank you very much in advance...I am performing an extensive series of tests to see why the engine keeps cutting out and will let you all soon know what I find out...thanks again.
tom
