1943 A transmission
kathy
02-13-2003 14:39:16
im new to john deere tractors i have a 1943 A hand start model and i want to change the trans oil but i dont know where to put it in after i drain it, where is the filler plug where you put the gear oil in?? hope this is not a stupid question but i just recently found out that this tractor does not have an oil dipstick spent a week looking for that!! thanks kathy in south dakota
Will P
02-13-2003 16:04:17
 Re: 1943 A transmission in reply to kathy, 02-13-2003 14:39:16
First, there is no "stupid" questions.
Now, The way to fill the trans/rearend is threw a filler plug back by the PTO shaft. Fill it up to the hole. But first, the trans and the rear end share the same fluid. There is another plug under the rear end. It is in-between the draw-bar supports that are bolted to the rear-end. You will need a 3/4"(?) square tube or a 3/4"(?) ratchet to get the plug out. I am pretty sure it was a 3/4" plug. That will drain what little is left by the bull gears. If any more questions, just ask.
Will P
