Rims
Jeff
01-04-2004 14:21:14
Where can I get a set of reproduction 8x36 deep well rims that bolt to cast centers?
Thanks
Duane Larson
01-04-2004 18:27:00
 Re: Rims in reply to Jeff, 01-04-2004 14:21:14
Jeff,
If you are referring to the types of rims used on JD's in the early days of rubber tires, the only supplier I am aware of would be Detwiler's. Rob has developed rollers for making this type of rim to replace bad ones on round spoke wheels. I don't know if they sell only the rims or not. www.detwilertractor.com
All other rims I am aware of are designed for wide-base tires introduced in 1938 - the above rim is designed for the "conventional" tire.
Jeff
01-04-2004 20:29:58
 Re: Re: Rims in reply to Duane Larson, 01-04-2004 18:27:00
Thanks Duane I'll give them a call.
