Rear End Oil for 49 A
Jeff
03-01-2003 07:52:59
What weight of rear end oil should I use in a 49 John Deere A? Thanks
Clooney
03-01-2003 10:16:44
 Re: Rear End Oil for 49 A in reply to Jeff, 03-01-2003 07:52:59
Jeff, that depends on the ambient temperature you are using your "A" at, the amount of wear in the trans & differential, the amount of noise it makes, & what's available in your area.
~The spec is 90 weight oil, but if you only use it in warm weather, or there is a lot of wear in the trans, or it is noisy, you could use 140 weight.
~A lot of people use 140 weight in those old "A's" to quiet them down a little, the 140 is a little stiff for cold weather use though.
