2-speed Model A Transmission?
AlbertoV05
03-01-2003 15:25:00
Can someone please explain what a "2-speed" transmission is on a Model A? It was described to me as basically a three-speed tranny with a seperate lever that is engaged to give you three more speeds.
Is this thing rare or pretty common on the old A's?
Thanks in advance
Al in Iowa
Doc
03-01-2003 19:52:26
 Re: 2-speed Model A Transmission? in reply to AlbertoV05, 03-01-2003 15:25:00
Al,
The "Two Speed" was how steel wheel A's were equipped. I have a 40 that has a "two speed", meaning it has two forward gears, with the hi-lo lever, giving four forward speeds. Rubber tired tractors had three forward, with hi-lo, giving six total. My 40 must have been a steel wheel model when sold, but was converted to pressed steel later. Deere probably didn't want anyone going too fast on steel, it was quite a ride!
My two cents, somebody jump in and correct me if I'm in error!
Docster
JD70Jim
03-02-2003 14:30:26
 Re: Re: 2-speed Model A Transmission? in reply to Doc, 03-01-2003 19:52:26
When the model A was first designed, there were 10 prototypes, designated model "AA-3" or "AA-4". The number designated whether it had a 3 speed of a 4 speed transmission. The Three speed was not adopted.
The Production tractors were originally equipped with a 4 speed transmission, operated by TWO levers. One lever had reverse, 1-3, and 2-4 on it, with the other lever being your "high-low" selector.
Starting with sn 499,000 all tractors were built with a six speed transmission. For tractors shipped on STEEL WHEELS, the 5th and 6th gears were blocked out. They were "IN" the transmission, but you could not access them. These tractors ALSO had a two lever shifting system---Reverse, 1-3,2-4 and 5-6, plus "high-low".
Beginning with sn 648,000 a single lever, six position shifting quadrant was used. I believe that the very few "A" tractors shipped on steel wheels after sn648,000 were still shipped with 5th and 6th locked out.
My 2440 still uses a two lever shifter---Park, I, II, and R plus 1-5,2-6,3-7, and 4-8 AND it has the hydraulic (like a TA) high low as well, giving 16 forward speeds, and I wouldn't try and refer to it a a 2 or 4 speed tractor either.
CMB
03-01-2003 21:15:37
The 1940 A's were all 4spd. 41s (499,000 up) were the first 6spd A's.
Dave K
03-01-2003 16:33:21
Not rare no. factory standard to be exact. The 50 models or maybe the 49's came out with the actual six speeds on the stick and no hi-lo lever.
Pappy
03-01-2003 15:50:38
You have it about figured out. These are six speed transmissions, but with only three gear speed selections. One gear is 1/3, one is 2/4 and one is 5/6. You select the gear you want, then select the high/low speed. For instance, you can change from second gear to fourth gear just by changing the high/low speed selector. The later transmissions used a similar arrangement, but the high/low selector was done internally by the main six speed gear selector.
AlbertoV05
03-01-2003 18:04:00
 Re: Re: 2-speed Model A Transmission? in reply to Pappy, 03-01-2003 15:50:38
Thanks for the education, guys!
Al in Iowa
