AR pulley bearing
Johan
03-03-2003 09:14:24
Want to change pulley bearing on AR #266xxx. Would SKF # NU 209 ECP be the same as Hyatt 1209? The SKF bearing inner diameter is 45 millimeters. Thanks.
Clooney
03-03-2003 13:32:54
 Re: AR pulley bearing in reply to Johan, 03-03-2003 09:14:24
Johan, I can't find a listing in my bearing chart for a Hyatt 1209. Most bearing numbers are the same from different manufacturers for the same size bearing size & I show the 1209 number to be.....ID=45mm...OD=85mm...width=19mm.... I can't seem to cross that SKF # NU 209 ECP to the Hyatt. ~Have you tried Deere for that bearing? I have found in a lot of cases on those old Hyatt bearings that Deere is cheaper than the bearing houses.
Johan
03-04-2003 06:59:47
 Re: Re: AR pulley bearing in reply to Clooney, 03-03-2003 13:32:54
Thanks Clooney, I think I will go for Deere to be on the safe side.
